1 - 9 of 9 Posts
i have a 4 lug setup but i want to change to 5 lug and i saw some junk jettas layin around in north calif and has 5 lugs on it.. can it be done on my car?
Modified by Jettaboy17 at 10:44 PM 2-12-2004
Re: Vr6 5 lugs conversion (Jettaboy17)
how exactly are you going to do that? all i know of is the conversion crap that is hella expensive, but i may be dumb
Discussion Starter · #4 ·
Re: Vr6 5 lugs conversion (VdubVr6PowR)
Quote, originally posted by VdubVr6PowR »
piece of cake..whats ur reasoning for doing it?
the reason is... BBS WHEELS!!!!!!!!!!! :-D also i want to know if the vr6 brakes would work on my car?
Modified by Jettaboy17 at 10:46 PM 2-12-2004
Do a search. You need ALOT of parts...
Fronts (11.3's)
Swaybar and related hardware (end links)
Control arms, both right and left
Ball Joints
Complete hub assemblies
Rotors
Carriers
Calipers
Brake lines
Axles- either just outer CV's or complete axles
Rear (from drum)
Stub axles (spindles)
Rotors, with bearings
caliper carriers
calipers
brake line
e brake cable..
The ONLY part you can do without is the front sway bar. That's it. If you find a car that has all the suspension intact, then go for it. Otherwise, it's not worth it. I've spent over $1k on my conversion...
Discussion Starter · #8 ·
Re: Vr6 5 lugs conversion (HockeyDork)
damn $1k?
but great prjoect for ya. not for me lol well i guess i better be lookin for a jetta vr6
I love my 11.3 convo.
I scored used parts for the brake convo with x-drilled and sloted brembo rotors, his used H&R coilovers, black de wheels with rubber, and a big master cylinder. It ran me $700, for everything. Let the hate out, i love it..
1 - 9 of 9 Posts
