1 - 6 of 6 Posts
Re: vr6 noob here needs help (volkswagonforlife)
Dunno about the axles, but the tie rods are pretty easy. I used the universal tie rod tool form Harbor Freight, but I've read it's doable with a narrow enough open end wrench (such as a spanner wrench used in bicycle repair).
Axles are again another easy thing, I think easier than tie rods. But, it would be nice if you could state what year vehicle you are working on.
Re: (volkswagonforlife)
I replaced both driveaxles on my '97 Passat a few weeks ago. I got the replacement axles at NAPA, they were $87 and have lifetime warranty. I would not say it was too difficult, but I did run into a few things that made it a PITA -- my drivers side axle was stuck in the hub pretty badly, and I had some problems removing the hex bolts that hold the axles to the transmission. It will take at least 8 hours and some swearing, but it's not too hard of a job if you have the right tools. On each side, you are basically undoing the big 30mm nut that holds axle in the hub, undoing the 2 18mm bolts that hold the struts, then 8? hex bolts (7mm? get the right hex bit, it's very important) on the transmission side. Reverse procedure to re-assemble, alignment is needed afterwords.
Stan
1 - 6 of 6 Posts
