Status
Not open for further replies.
1 - 14 of 14 Posts
Re: vr6 = v6 (Andrew Foss)
the logic behind this...but amo not sure of what the new DOHC vr6 setup is but...being a DOHC, VW might haveta split the head for 4 camshaft (2 cam for each head)...before it was an SOHC vr6, so only 2 cams are needed so it will fit over one head...just a guess base on what i've heard
o by the way..thats because vr6 means narrow angel v6 in german i think...but since you must split the head to make it DOHC, its not long narrow angle..thus now a v6
[Modified by 87GolfKart, 3:59 PM 2-12-2002]
Re: vr6 = v6 (Jerelin7686)
quote:[HR][/HR]my brother told me that they stopped calling the vr6 the vr6 and now just refer to it as a v6... any truth to this?[HR][/HR]​
It is true. Since the introduction of the 4th generation Golf/Jetta, the R has dissapeared, they are only badged as Golf V6 or Bora V6
[Modified by PerL, 2:35 AM 2-13-2002]
Discussion Starter · #8 ·
Re: vr6 = v6 (PerL)
quote:[HR][/HR]It is true. Since the introduction of the 4th generation Golf/Jetta, the R has dissapeared, they are only badged as Golf V6 or Bora V6[HR][/HR]​
thanks thats what i wanted to hear...
for all the people that gave me a lesson on the setup of a vr6 vs a v6 i already knew that stuff i just wanted to know if it was true that they were badging it as a v6....
· Banned
Re: vr6 = v6 (vorsichtcanada)
vw makes a 3 litre v6 that is mounted longitudionally in the engine bay
the VR6 cars ( GTI GLX) are still badged VR6
the b5's are not VR6 they are V6 hope this clears everything up
Re: vr6 = v6 (1phtgti)
This will (hopefully) make it easier.
If the car has a transverse engine it is the VR6 in there. These cars are G/J A3 (93-99), G/J A4 (99-up), Passat B3(89-94) and Passat B4(95-97).
The Passats from 98-up to today have the Audi V6 engine. This one is a traditional 60º unit, and is used in the Passat because the Passat shares the floorpan with the Audis A4 and A6.
2006 P+ A4 3.2 Avant, 2011 C'Dale Bad Boy, 2014 C'Dale Carbon Synapse, 2019 P+ Q5
you start a major complaint about OT stuff being locked and then this?
1 - 14 of 14 Posts
Status
