Quote, originally posted by bretter » |
ok. vr6t w/ 475cc injectors, atp 475cc chip<
![]() 3.0 bar fpr, walbro 392 intank fuel pump. car runs super rich once in boost... ~10.0:1's all way to redline. running 12 psi boost w/ copper hg and arp headstuds . would a 2.0 bar fpr help? or will dropping the base pressure going to do anything? is remapping the chip the only solution? Modified by bretter at 3:34 PM 7-12-2003 |
Quote, originally posted by vr6turbin » |
Way u put 475cc injectors?? go with the 310cc and then u will not be so rich...(thaing about that?) and BTW if u boost 12 psi u don't need injectors bigger that that |
good to 22 psi? cool. thanks gtrtim. |
Quote, originally posted by mattstacks » |
Esp. not with that chip. |
