1 - 6 of 6 Posts
ok long story short.. basically eip stage one on a obd2 motor with c2motorsports stage II fueling upgrade... put the car back together and everything seems pretty much o.k. but every time i go into boost, it throws up random/multiple cynlider misfires and cylinder 5 misfire and cylnder 6 misfire, all come as intermittent codes and every now and then a maf sensor signal too high code also intermittent.. doesnt seem to run bad tho, i am jus worried a lil, i scrapped one vr6 last season and i dont want to do it again, the only problem i can really feel is a part throttle before it goes into boost, it seems choppy, hesitant, however u want to put it... but then hits boost and goes fine.. any help would be appreciated, and does anyone know exactly how and what to look for one vag-com so i can monitor this stuff.. i wanna crank the boost up but i def. want to fix this problem first.. either way http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif to the crew at c2motorsports and def. chris..... products are amaxing and i would recommend to anyone... so if anyone can please help me out i would greatly appreciate it.. thanks
Re: vr6t throwing codes..need help!!!!!!! (eurogordy)
its normal.. I get those codes all the time and the car runs fine.. If it does run like crap, talk to jeff..
Re: vr6t throwing codes..need help!!!!!!! (yokomomma)
its normal for the kit to do that.. Its not normal for our cars to do that.. bah, whatever..
to make everyone happy "Almost everyone with the C2 kit is having that problem, don't worry about it too much. If you want a fix for it, talk to Jeff.".. There better?
Administrator
Re: vr6t throwing codes..need help!!!!!!! (MunKyBoy)
Quote, originally posted by MunKyBoy »
I think Jeff could fix it ...
But then you wouldn't be getting that extra power that everyone loves at part throttle with C2/jeff's setups...
AFAIK, you don't get a CEL with those codes so I'd say don't worry too much about it.
My car ran effin awesome and I threw multiple misfire codes...
If you want the straight skinny IM jeff or c2 and find out exactly why...
But remember, it's tough to please everyone...
And c2 seems to get good power w/o banging off the knock sensors - which is pretty damn cool IMO.
Later,
Re: vr6t throwing codes..need help!!!!!!! (nater)
def. http://****************.com/smile/emthup.gif for c2motorsports and the crew, i was jus tryin to figure this out so i didnt pop another vr6, they arent gettin ne cheaper to rebuild
, but i guess i can crank up the boost now and see what happens, those of u runnin the fueling software and their
head spacer, what kind of psi are u runnin and anybody got ne nice solid numbers as far as hp, torque, q. mile times, etc...
I'm running just 9PSI and i've ran a 14.1 at 102.. its a shiety time but with some better tires and a driver that knows what he's doing, lol the suck = Me, im sure i could be running mid 13's.. The kit is good to about 16-17 psi, so you can imagin' what kind of times you/I/we could be running at that http://****************.com/smile/emthup.gif
1 - 6 of 6 Posts
