1 - 6 of 6 Posts
Discussion Starter #1
Building a VRT project need some info on injectors, I will be using C2NER from c2 with a #36 injector tune.
What needs to be done to get the to fit #36 BOSCH injectors to a mk4 intake manifold?
Yes i aware that i can buy them already modified from c2, I built this kit all second hand.
also this will be an automatic car if that matters.
thanks
Mk3 VRT, Mk4 VRT, B5 VRT, A3 VRT, B6 VR, B5 BT
Light machining/sanding to remove some of the lower shoulder off the injector allowing it to seat properly in intake manifold.
Literally just machine down the side shoulder of the injector to allow it to seat fully in the injector cavity of the manifold. I will take a pic of some of mine and post. I have 36lb and 42lb already modified that I can provide you with if interested.
1 - 6 of 6 Posts
