first off atp kit 440 webber injectors t3/t4 50 trim garrett internal wastegate atp manifold/intercooler. fresh stock pump and filter. 18 vac at idle running 8-10psi.stock intake.
Alright now when im getting on it hard, it feels like it its shuddering up top. didnt before so i changed the fuel pump and filter. worked fine for like a day, then same problem. no vacum leaks when its cold then after a hot run the rpms jump like 200rpm. only code is a front o2 sensor. kinda broke at the moment could be anything else?
