Can the VAG-COM be used to adjust the distanced traveled my the window when the door is opened ?
The windows on the Eos drop a small distance when opened to allow th glass to clear a seal, and once the door is closed, the window rolls back up that small distance to give the window "bite" into the seal.
I have noticed that the max window up with the door open and top down is also different (lower).
Is this drop in any way adjustable via the VAG-COM ?
