1 - 3 of 3 Posts
I have a 1974 VW 412 with a 1980 VW Vanagon engine in it, for some reason i cant get the fuel injectors to work on there own. If i put power to them direct they they work fine. I switched the computer and i still have the same problem. The car will run off starting fluid and the cold start injector but then after that it dies. There is power going to the computer too, i just dont now what else it could be wrong. When i turn the key on the fuel presser goes to 55lb then once i start cranking the engine it drops to about 30lb and keeps droping all the way to 15-20. Could this be the problem? It still seems like it sould start and run untill the presser drops. Could it be a bad pump or presser regalator?Any advice would be great.
Your Truely, Confused VW owner
1 - 3 of 3 Posts
