VW Golf MK5 CAN-BUS with Navigation Coding?
5.3K views 5 replies 4 participants last post by  Uwe
Re: VW Golf MK5 CAN-BUS with Navigation Coding? (davidpeternolan)
Quote, originally posted by davidpeternolan »
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Not registered 0001
02-Auto Trans -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0001
62-Door,Rear Left -- Status: OK 0000
Not sure why but somehow you messed it up, the installation list (same as the coding in this case) is missing the engine and the radio. The new (proper) coding value should be... 3F3F0148073001
...is it possible there was a bug in VDS Beta 802.1 that caused the wrong bit to be set/cleared?
Possible, sure. Reported yet, no.
You may want to update your VCDS Beta to the latest 803.3...
http://www.ross-tech.com/vag-c....html
