Re: VW Motorsport 16v fuel infection (RavenGTi)
quote:[HR][/HR]aluminum housing and plate. injector flow can be metered individually. bowl profile is different. i dont know if he has changed the description yet (he had the same description as the regular euro inj) but you can look here (its where eurotrash got his from):
europartsinc.com
edit- 130_R i just saw the "E" in your post. no its all mechanical
[Modified by RavenGTi, 10:19 PM 4-11-2002][HR][/HR]
OK, thanks.
Here are a couple of suggetions:
check total system pressure
pull out an injector and tweak the mixture screw
make sure the air metering plate is properly set
check for shims in the fuel distributor
HTH http://****************.com/smile/emthup.gif
