Yes, BUT shifter gear position pin needs to be carefully heated with heat gun or hair dryer and rotated 90 degrees with screw driver or of such.
I read about that, but will the trim panel fit plug and play in the same place, or will be some modifications or mayebue no fit at all.Yes, BUT shifter gear position pin needs to be carefully heated with heat gun or hair dryer and rotated 90 degrees with screw driver or of such.
