VW PASSAT VCDS-Lite Codes for my problem w/ misfiring cylinders HELP! PLEASE!?
HOw would i go about this issue?
Ignition Coil? Ignition Coil Wires? Spark Plugs? ALIENS? etc.
Please Throw all good ideas at me and i will shift them through and and come up with the solution.
What would be the solution to the below faults?
Thanks in advance.
[email protected]
Address 01: Engine Labels: 000-907-000-ATQ.LBL
Controller: 3B0 907 551 CR
Component: 2.8L V6/5V G 0004
Coding: 07551
Shop #: WSC 05311
WVWWH63BX0000000 VWZ7Z0B0000000
4 Faults Found:
17803 - Ignition Coil Power Output 3: Electrical Malfunction
P1395 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
Readiness: 0000 0000
2003 VW B5.5 Passat Wagon GLX 2.8L 2771CC V6 ATQ GAS MOTOR DOHC Naturally Aspirated.
Thanks in advance.
[email protected]
Coding: 07551
Shop #: WSC 05311
4 Faults Found:
P0300 - 35-00 - -
P0305 - 35-00 - -
P0303 - 35-00 - -
