1 - 20 of 63 Posts
Banned
VWR Sport Springs
We have received our shipment of VWR Sport Springs. They are in stock ready to ship. We are also running a special on the local installs for $629.00 out the door including tax, labor of install and alignment
(Click image for more information or to order)
VWR Sport Springs are specifically engineered to replace your factory springs with slightly shorter and stiffer springs. They are designed to lower your vehicle's center of gravity and reduce body roll for better handling all while maintaining the ride quality and comfort as if intended by the OEM. VWR found the current VAG OEM dampers are a much more sophisticated design than previous generations resulting in a worthwhile improvement in handling with little change. VWR painstakingly developed these springs to work perfectly with your OEM dampers and require no other changes to your suspension to take advantage of their benefits.
The VWR Sport Springs were developed for several VAG platforms all matching correctly to their respective OEM dampers, making this a very cost-effective modification. With different engines and vehicle weights, VWR has developed a range of springs specific to your vehicle and powertrain. These springs are fully compatible with Volkswagen's Switchable ACC (Adjustable Chassis Control) dampers.
A typical VWR Sport Spring customer is one who demands performance over stock without breaking the bank. These springs are not intended for customers looking to dramatically lower or track their vehicle. For those customers, VWR's full line of coilovers are available to suit your individual needs.
Engineering
Many springs available for VAG vehicles were either designed to be coupled with aftermarket dampers or are simply available to lower and stiffen the vehicle without any testing to stand behind the chosen stiffness or ride height. Through extensive development and testing, the VWR Sport Springs were optimized for each vehicle platform. Tens of thousands of miles across multiple vehicles were necessary to determine the ideal specifications for each spring set and VWR is very proud of the end results. VWR can guarantee with confidence they believe these springs to be the best for your VAG vehicle on the market.
Reducing Ride Height and Increasing Spring Rate
Each vehicle will be lowered differently, depending on platform. Most vehicles see a 20-25mm reduction in front and rear ride height. These heights were chosen in order to preserve the wheel travel needed to keep the usability of the standard car, with an increase in spring rate of around 10-15% depending on the type of car. Lowering or stiffening further, as some springs do, in VWR's experience will cause the vehicle to bounce and lose damper control as the dampers are mismatched to the spring-rate and will also cause the springs to run out of wheel travel. You also risk reducing the life of your dampers significantly by choosing the wrong springs, which the VWR Sport Springs are guaranteed not to do.
VWR does not recommend sport springs on 4-Motion vehicles such as the Golf R and R32 as lowering the ride height from the factory does not offer a significant improvement and can even harm the ride and handling balance of these vehicles. For these vehicles the VWR Streetsport and Streetsport+ Coilover Systems are highly recommended.
Lowering Spring Style and Spring Rate
VWR Sport Springs are a linear rate spring with a barrel-type shape so the end forms come slightly in. The springs have specific front and rear spring rates as seen below in the technical data table. This allows VWR to preserve the ride quality in normal use, but stiffens the spring rates at the ends of its travel when cornering or braking hard. The springs come in power-coated gloss VWR blue with Volkswagen Racing Logos and work especially well when combined with APR Roll Control or VWR Sway Bars.
Current - 17 Passat SEL Past - 02 337, 04 r32, 11 CC, 11 GTI, 16 Passat S
Okay.. Thanks! Im thinking about ordering these in the future sometime.
Do you have any pics compared to stock, to see ride height difference.. ??
I may be interested in the springs if I could get dbc to return the bent intercooler they sent me. As it stands, I can't get anyone to return my calls, emails, etc.
1 - 20 of 63 Posts
