Re: VWvortex R32 Stock Dyno Numbers (eiprich)
My dyno was 189.6 whp at 5500 RPMS and 214.7 LBFT at 3000 RPM's. I have the numbers correct, have to check the RPMS once I look at the sheet which is down in the car! (corrected) Car would not pull past 5500 rpms on the Mustang even though HP was still going up! 4th gear pull so I don't think it was hitting the speed limiter unless they were in 5th. What rpm does 130 MPH come at in 5th?
The VW spec book rates the car at "241hp at 6250 RPM" and "236 ft. lbs. at 2800 rpm." Manual 3.3, page 4!
This was an AWD Mustang Dyno at AWE, dialed at 3400 lbs, 1600 miles on the car, exhuast valve open!
Weird that I have the most tourque out of these three dyno's using a full load and all 4 wheels!
Rich and Jamie, how many miles on the clock with your dyno sessions, did you find the speed limiter, what gear, what RPM?
Anthony
Modified by 95GLX at 6:08 AM 3-17-2004
Quote, originally posted by eiprich » |
I spoke with Anthony (95GLX) and he has dynoed his car as well but on a Mustang AWD dyno. -Rich |
Anthony
