Re: ([email protected])
Wheel horsepower is the amount of power being transmitted from the tires to the rollers, or to the road. This power is significantly lower than crank horsepower (at the output shaft of the engine) due to several factors including:
clutch slippage
gears intermeshing at the input shaft to the transmission
gears intermeshing between gears in the transmission
drag induced by transmission fluid
gears intermeshing at the output shaft to the transmission
gears intermeshing inside the differential
gears intermeshing between the differential and half-shaft
gears intermeshing at the CV joints
Wheel bearing drag
tire deformation
tire slippage
Many of these factors behave very differently during a coast-down and some aren't applicable at all. There is no way to accurately measure crank horsepower with a chassis dyno. Period.
Quote, originally posted by [email protected] » |
The MAHA creates its own correction factor based upon the individual car. IMO that would be the most accurate. I don't know enough about it though to really understand how it works. Apparently though - it has been accurate to 1-2 hp on determine HP on stock cars. |
clutch slippage
Wheel bearing drag
tire deformation
tire slippage
