Want to do euro tails, where do I get the parts?
525 Views 13 Replies 9 Participants Last post by  mk2jetta
I would like to do the euro tail lights on my rabbit. Where can I get the tail lights and the section of metal that needs to be welded in to hold the lights? Also, does the wiring need to be changed or will it plug right in?
Thanks in advance....
1 - 14 of 14 Posts
Re: Want to do euro tails, where do I get the parts? (schleppy)
http://forums.vwvortex.com/zerothread?id=169239
See less See more
Re: Want to do euro tails, where do I get the parts? (white rabbit)
I might be able to help what exactly do you want?
See less See more
2
Re: Want to do euro tails, where do I get the parts? (Cullen)
I need backing plate and bulbholders!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
Re: Want to do euro tails, where do I get the parts? (FlugGTI)
Wide model or?
Well, I would like to fit the smallest ones possible (clear or redgular tails). But I heard that you need to cut out the whole area that holds the lights and weld in a new one.
You tell me what I need
See less See more
The smallest tails possible would be the one's from the early Rabbits that we had here, '80 and down and from all years of Cabbys that we got here.
They look like the ones in the top picture in Cullen's post.
Re: Want to do euro tails, where do I get the parts? (rabbitmania)
Ok, that is what I want. What do I need, asides from the tail lights, to install them in my 84 rabbit? What bodywork is required?
what are the differences between USA Cabby and Euro Cabby lights anyway?
arent they the same?
2
I WANT THE SECOND!!! http://****************.com/smile/emthup.gif
hook me up!
See less See more
Re: Want to do euro tails, where do I get the parts? (83Rabbit)
Some german rabbits came with a blackk plastic pieces that go between the little tail lights and you cann use this on US cars
Re: Want to do euro tails, where do I get the parts? (aginghare)
I have heard of people doing what aginghare described above. I think cabrio_boy here has done it to his Rabbit.
In my posted pic:
1. Older A1
2. Newer A1
3. Jetta A1
all euro.
you only need to weld two metal plates i think, one on each side
and euro golf1 lights are way nicer than the small ones
well anything is nicer than those 3-footers we got in north-america
See less See more
1 - 14 of 14 Posts
