1 - 6 of 6 Posts
i just installed it and running extremely rich
help is very appreciated.
o2 sensor burned because of fuel
thanks!!!!
it for a NA 2.0l 8v with 450cc
Modified by almostvr6 at 6:05 AM 2-14-2004
Modified by almostvr6 at 6:23 AM 2-14-2004
Re: wanted:sds em4 f 2.0l 8v naturaly aspired fuel map and timing (almostvr6)
What are you running for a N/A setup that needs 450cc injectors?
Banned
Since you have sds, just turn down the fueling until it stops running rich and then get it on a wideband to do fine tuning.
Re: wanted:sds em4 f 2.0l 8v naturaly aspired fuel map and timing (GTibunny16v)
how about i make life easier for you and you switch your 450's for my 310's ? LOL
ditch the o2 sensor man, run it open loop, reasons liek that are why we went stand alone, screw the o2
Re: wanted:sds em4 f 2.0l 8v naturaly aspired fuel map and timing (VW97Jetta)
had to take 450cc talon because of resistor box and going turbo this summer .thanks!!
Discussion Starter · #6 ·
having problemes idling and starting in the cold . cold start values!!! i guess i have to go on the dyno for tuning pretty soon!
thanks for the help!!!!
1 - 6 of 6 Posts
