1 - 20 of 64 Posts
Re: War and Peace over cross-drilleds (DanG)
Heh. On page 3, that guy Cobra, posts the most thorough and complete "flame" I've ever seen on the Internet. It completely disassembled the nutjob that started the thread. Beautiful, just beautiful.
Banned
Re: War and Peace over cross-drilleds (Lackey)
quote:[HR][/HR]Heh. On page 3, that guy Cobra, posts the most thorough and complete "flame" I've ever seen on the Internet. It completely disassembled the nutjob that started the thread. Beautiful, just beautiful. [HR][/HR]​
Nothing like arming a salesman with just enough knowledge to stick both feet in his mouth. Of course, this is after he pulled his head from his... well, you know.
Re: War and Peace over cross-drilleds (vuu16v)
I thought this was the funniest post (from about p13, and obviously very censored):
quote:[HR][/HR]
Kevin, on the other hand. . . . Dude, what have you got going for you in life beyond being an ignorant hired hand at some little performance shop in God-forsaken Arizona? Exactly where did you earn your degree in knowing a GODDAMNED THING? You tell me how I talk so much poop, but what the hell comes from your own proximal orifice? The same thing as what comes from your distal orifice, only less opaque and in far greater quantities. I suggest you humble yourself a tad bit, and learn from what has been offered to you and the rest of the readership of this board as an educational experience. I would venture a guess that everyone who wasn't already committed either to you or themselves to buy some of your 'holy-rotors' will certainly think better of it after having read this thread and the info for which links have been provided. [HR][/HR]​
Re: War and Peace over cross-drilleds (Bimmer)
quote:[HR][/HR]Let's look more in-depth at each step now shall we? No? Too bad assclown we are doing it anyway. [HR][/HR]​
Nice! This provided me with the entertainment I needed to pass the morning.
It's too bad on that board how everyone mindlessly follows exactly what the moderator says, even though he fails to address the issue of x-drilled rotors cracking.
[Modified by Gelly, 2:46 PM 4-11-2002]
Re: War and Peace over cross-drilleds (GermaniuM)
quote:[HR][/HR]So did anyone figure out that cross drilled rotors on the Porsche GT2 are actually ceramic?
[HR][/HR]​
porsche rotors are not drilled as far as i recal.. they are cast with the holes in them
Re: War and Peace over cross-drilleds (VwG60Kid)
porsche rotors are not drilled as far as i recal.. they are cast with the holes in them[HR][/HR]​
I know that, but what am I supposed to call them cross casted rotors
2019 Pajero Sport and 1999 100 series LC
So, to sum up (I guess because I didn't read every page).
Brakes depend on friction.
Friction generates heat.
This heat is absorbed primarily by the discs.
The heat is disappated by the discs.
If not disc temps remain high and pad temps increase.
Increased pad temps can result in...pad glazing, increased fluid temp and fade.
The amount of heat absorbed by the discs is dependant on the size, mass and material so larger, heavier and carbon discs will absorb an increadable amount of heat before they reach a critical temp. Now as far as disappation is concerned their is a trade off between surface area and volume. Ie if the discs are small they will not disapate the same amount of heat nearly as fast as a larger discs. That and I suspect they will get hotter faster give equivelent pad size. So I would think that smaller discs might require some addtional ventilation be it cast or drilled holes to compensate for their reduced surface to volume.
Sound right?
Cheers
Chris
Re: War and Peace over cross-drilleds (CBJ)
quote:[HR][/HR]So I would think that smaller discs might require some addtional ventilation be it cast or drilled holes to compensate for their reduced surface to volume.[HR][/HR]​
In an ideal world this might be true but there are several things to remember:
- Drilling removes metal. Less metal means less mass to dissipate the heat.
- You spend the majority of your driving time NOT on the brakes. Since this is the case there are other ways to effectively aid in the cooling of the rotors without drilling them. On an average lap at say VIR I will estimate that I am on the brakes for a total of about 15-30 seconds of a 2:25 lap. That leaves about 2 minutes for the brake ducts to vent cool air onto the rotors to help cool them. I also brought up the point of how often do you fade your brakes on the street? If you aren't fading stock brakes do you really think there is a need for additional cooling?
- The drilling IS NOT really intended to increase cooling efficiency - that is just a byproduct of it. The drilling is to allow for gasses and dust to escape from in between the pads and rotor.
- The drilling weakens the rotor. On a larger rotor thereis more mass to distribute the forces over. Smaller rotors do not have this luxury so not only is the removal of the material cutting down on the amount of heat transfer medium but it is also cutting down on the structure of the part. On brakes this is bad.
Hope that helps a little.
[Modified by Cobra, 10:09 PM 4-11-2002]
Re: War and Peace over cross-drilleds (Cobra)
Hey Cobra, I for one would like to say that your post on the Altima board was very informative; despite the fact that no one on there seems to understand simple physics.
Wow, sort of hoped you'd hop over and answer my question. I see your point but you might want to use "absorb" as opposed to "dissipate". The disc is absorbing the heat and removing it from the "system" while actively breaking and dissipating the heat upon release of the breaks. I was confused at first by your terminalogy. Otherwise I agree.
Cheers
Chris
1 - 20 of 64 Posts
