Hello Community,
I'm helping a friend with their 2007 Audi Q7 with 157k miles. The front passenger side has been leaking water. After doing some research, I see the under footwell drains get blocked by dirt & debris and the AC drain gets blocked so I will be checking them today hopefully.
However, the issue I need your help with is to determine what got damaged as the infotainment system doesn't work or will randomly turn on while driving, the heater doesn't work and I'm sure several other things don't work that I have yet to discover.
The autoscan is complaining about several components that have malfunctioned or cannot be reached. Is it the ECU that got damaged or wires under the carpet that could throw these codes?
Here's the scan.
Here's the scan.
Code:
Saturday,09,October,2021,21:59:01:58921
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: REDACTED License Plate:
Mileage: 251890km-156517mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 37 3C 42 46
47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: REDACTED Mileage: 251890km-156517miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1353
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 6889460F5E7DB9DB273-803C
2 Faults Found:
049425 - No Communication with Battery Energy Control Module
U0111 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 249940 km
Time Indication: 0
Date: 2007.12.18
Time: 04:57:38
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.430 V
009488 - ECM/PCM Power Relay Sense Circuit
P2510 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251892 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4017895
Coding: 0000002
VCID: 290F030B85F740D3F8D-807C
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 2809060F9EFD79DBE73-807C
3 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 249504 km
Time Indication: 0
Date: 2007.09.25
Time: 03:53:40
Freeze Frame:
Count: 12544
Count: 8197
Count: 288
Count: 50432
01276 - ABS Hydraulic Pump (V64)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 36
Reset counter: 30
Mileage: 250549 km
Time Indication: 0
Date: 2006.11.27
Time: 05:44:59
Freeze Frame:
Count: 7680
Count: 8195
Count: 104
Count: 48896
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 44
Mileage: 251886 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:02
Freeze Frame:
Count: 128
Count: 13057
Count: 297
Count: 41472
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100685972
Coding: 0000135
VCID: 63935123A75BDA83F21-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
9 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 11
Reset counter: 84
Mileage: 236250 km
Time Indication: 0
Date: 2006.12.09
Time: 00:04:40
00192 - Rear Left Door Handle Touch Sensor (G417)
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 13
Mileage: 236155 km
Time Indication: 0
Date: 2006.11.23
Time: 12:43:45
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 250548 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:08
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 0 km
Time Indication: 0
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 31
Reset counter: 84
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:20
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 6
Reset counter: 84
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:24:47
00955 - Key 1
Freeze Frame:
Fault Status: 01110010
Fault Priority: 3
Fault Frequency: 38
Reset counter: 99
Mileage: 248386 km
Time Indication: 0
Date: 2007.07.09
Time: 12:50:11
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 84
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:23:50
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.24
Time: 16:03:09
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030029964
Coding: 0786470
VCID: 619F5B2BBD47C893E0D-8034
5 Faults Found:
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 84
Mileage: 250280 km
Time Indication: 0
Date: 2008.02.16
Time: 06:30:32
Freeze Frame:
Temperature: 7.0°C
Speed: 0.0 km/h
(no units): 0.0
(no units): 193.0
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 44
Mileage: 250582 km
Time Indication: 0
Date: 2006.12.05
Time: 08:16:51
Freeze Frame:
Temperature: 26.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 249940 km
Time Indication: 0
Date: 2007.12.18
Time: 06:09:18
Freeze Frame:
ON
Bin. Bits: 001111
01844 - Control Module for Fresh Air Blower (J126)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 249940 km
Time Indication: 0
Date: 2007.12.18
Time: 03:12:52
Freeze Frame:
Temperature: 19.0°C
Speed: 0.0 km/h
(no units): 0.0
(no units): 192.0
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 84
Mileage: 251892 km
Time Indication: 0
Date: 2006.11.23
Time: 12:01:07
Freeze Frame:
Bin. Bits: 01111
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0014123
VCID: 313FEB6BAD27381330D-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 241140 km
Time Indication: 0
Date: 2007.03.11
Time: 00:05:00
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH41 0230
Revision: 05H41000 Serial number: 0038QD053VSV
Coding: 0014131
VCID: 2B03F9038F0B52C30A1-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME221026671
Subsystem 3 - Serial number: 6342QSME22104B0FB
Subsystem 4 - Serial number: 6352QSME1F3A1441G
Subsystem 5 - Serial number: 6362QSME221377459
Subsystem 6 - Serial number: 63734SME1D771B69D
Subsystem 7 - Serial number: 63834SME1F7C457DN
2 Faults Found:
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054070340352
Coding: 0002042
VCID: 669548375469AFAB15F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 112
Reset counter: 44
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:21
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 84
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 84
Mileage: 0 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 251892 km
Time Indication: 0
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H18 0170
Revision: 00200000 Serial number: 5HH39HL27
Coding: 2641268
Shop #: WSC 30592 067 57207
VCID: 23131123E7DB9A83B21-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D07122814F
Coding: F5F7FE77747A02
Shop #: WSC 06133 444 52622
VCID: 6C813A1F4A8595FB43B-8038
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 84
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:21
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Mileage: 251499 km
Time Indication: 0
Date: 2007.01.19
Time: 08:28:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 84
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:24:48
00470 - Company Comfort Databus in Single Wire
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 84
Mileage: 251886 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.24
Time: 16:03:10
Address 1E: Media Player 2
Cannot be reached
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000100041
Coding: 0000006
4 Faults Found:
01849 - Temperature Sensor for Heated Seat; Rear Left (G94)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 13
Mileage: 236155 km
Time Indication: 0
Date: 2006.11.23
Time: 12:54:37
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 10
Reset counter: 117
Mileage: 236239 km
Time Indication: 0
Date: 2006.12.08
Time: 13:38:03
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 84
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.22
Time: 14:37:25
Freeze Frame:
ON
Bin. Bits: 001101
00003 - Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 237871 km
Time Indication: 0
Date: 2007.01.27
Time: 22:06:06
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 44
Mileage: 237568 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 84
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:24:47
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0000001
VCID: 2D07F71BB11F5CF3145-8078
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F19.01.0700H0600000010190ÿ
Subsystem 4 - Serial number: 010190ÿ
1 Fault Found:
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 13
Mileage: 236152 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
VCID: 2F3BED13BB132EE3269-807A
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 44
Mileage: 251824 km
Time Indication: 0
Date: 2007.02.12
Time: 01:41:40
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 70
Reset counter: 84
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.20
Time: 22:39:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 83
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:24:49
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.25
Time: 06:18:00
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01033338200000
Coding: 7632925
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
5 Faults Found:
01696 - Footwell Lighting; Rear Left (W45)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 110
Mileage: 205310 km
Time Indication: 0
Date: 2016.12.19
Time: 14:48:58
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 44
Mileage: 236315 km
Time Indication: 0
Date: 2006.12.14
Time: 11:18:27
02956 - Lamp in Trunk/Hatch Lid; Left
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 44
Mileage: 243197 km
Time Indication: 0
Date: 2007.04.19
Time: 04:13:45
Freeze Frame:
Bin. Bits: 110 001
02957 - Lamp in Trunk/Hatch Lid; Right
Freeze Frame:
Fault Priority: 3
Reset counter: 44
Mileage: 243300 km
Time Indication: 0
Date: 2007.04.20
Time: 01:56:36
Freeze Frame:
Bin. Bits: 100 001
Freeze Frame:
Fault Priority: 5
Reset counter: 44
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:23
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000042908
Coding: 0012001
VCID: 5EE560D78C39F76BDDF-800A
3 Faults Found:
Freeze Frame:
Fault Status: 01110100
Fault Priority: 3
Fault Frequency: 104
Reset counter: 44
Mileage: 237568 km
Time Indication: 0
Date: 2007.01.21
Time: 15:40:00
Freeze Frame:
Voltage: 12.300 V
Temperature: 77.0°C
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 44
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 6.100 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 44
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:23:00
Freeze Frame:
Voltage: 8.100 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 44
Mileage: 249029 km
Time Indication: 0
Date: 2007.08.14
Time: 01:43:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 83
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 09:24:49
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
3 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 84
Mileage: 251880 km
Time Indication: 0
Date: 2006.11.23
Time: 13:06:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 76
Mileage: 251496 km
Time Indication: 0
Date: 2007.01.16
Time: 16:33:42
02627 - Dynamic Cornering Light Motor; Left (V318)
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Reset counter: 44
Mileage: 250024 km
Time Indication: 0
Date: 2007.12.23
Time: 06:43:31
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 44
Mileage: 251892 km
Time Indication: 0
Date: 2006.11.23
Time: 13:25:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 84
Mileage: 251892 km
Time Indication: 0
Date: 2006.11.23
Time: 13:41:46
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700041267
Coding: 0062424
VCID: 221D1427F8C1938BB97-8076
2 Faults Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 21
Reset counter: 83
Mileage: 250824 km
Time Indication: 0
Date: 2006.12.12
Time: 12:08:36
Freeze Frame:
(no units): 66.0
Voltage: 14.10 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 253
Reset counter: 0
Mileage: 250548 km
Time Indication: 0
Date: 2008.02.25
Time: 17:44:24
Freeze Frame:
(no units): 4.0
Temperature: 7.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control
Cannot be reached
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J71419H
Coding: 1001101
VCID: 2411123FE2D59DBBCBB-8070
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 251892 km
Time Indication: 0
Date: 2006.11.23
Time: 12:33:55
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 84
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 84
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD21.02.07--H21001001C0013ÿ
Subsystem 4 - Serial number: 1C0013ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 44
Mileage: 237570 km
Time Indication: 0
Date: 2007.01.21
Time: 20:40:20
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002480559-----
Coding: 0003595
VCID: 2615083794E96FABD5F-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
5 Faults Found:
00927 - Terminal 30 (Right)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 44
Mileage: 249029 km
Time Indication: 0
Date: 2007.08.13
Time: 21:52:49
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.26
Time: 13:13:45
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 83
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.19
Time: 14:05:41
02961 - Lamp in Bumper; Rear Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.24
Time: 20:04:57
Freeze Frame:
Bin. Bits: 010 000
02960 - Lamp in Bumper; Rear Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.23
Time: 13:28:46
Freeze Frame:
Bin. Bits: 010 000
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 44
Mileage: 250967 km
Time Indication: 0
Date: 2006.12.21
Time: 08:37:03
Freeze Frame:
Fault Priority: 3
Reset counter: 83
Mileage: 251493 km
Time Indication: 0
Date: 2007.01.19
Time: 06:39:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 251888 km
Time Indication: 0
Date: 2007.03.22
Time: 14:01:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.24
Time: 16:03:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 84
Mileage: 251893 km
Time Indication: 0
Date: 2006.11.24
Time: 16:03:10
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06240802302243
Coding: 0001006
Shop #: WSC 131071 1023 2097151
VCID: 270B053393E376A3EE9-8072
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 67
Reset counter: 178
Mileage: 236154 km
Time Indication: 0
Date: 2006.11.23
Time: 12:40:23
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 02:14, VBatt start/end: 13.9V/13.8V)-----------
