Well I am in the middle of replacing the water pump. I removed the A/C compressor and Alternator. I was hoping to undo the two lower acessory brackt bolts then lossen the top one that is accessible through the timing cover. It is a T-6 hex head. Of course the bolt won't budge and now its getting stripped.
I suppose I am going to have to remove the timing cover now? If so I guess I might as well do the timing belt too. I was hoping this would be a couple hour job. If anyone has any solutions let me know.
Thanks.
Thanks.
