Just got the Reimbursement Claim Form in mail. To see if you qualify if you don’t receive the mailing go to www.waterpumpsettlement.com and enter your VIN.
What is the benefit of opting out of the settlement?Looks like it supersedes the 6 yr/72k mile warranty and limits VW's responsibilty to a maximum of 1 water pump replacement/vehicle. I'm confirming this but that's what an attorney friend said after reviewing the settlement paperwork. I'm likely opting out of the settlement.
I was thinking the same thing, get this out of the way so I don't have to worry about it!Got the paperwork. But I have not had the work done as my pump has been 👍.
Assuming this wouldn’t cover premature replacement to avoid a future failure??
VW would continue to be liable for all water pump replacements and related engine damage to the end of the 6 year warranty period rather than just the first time it happens. If it is like my Passat it took the dealer 3 tries to get a water pump in that didn't leak. Under this settlement I would have had to pay for the last 2 replacements. The risk is that I might have to foot the bill myself if the water pump the fails the first time after the 6 year warranty .What is the benefit of opting out of the settlement?
You can litigate on your own.What is the benefit of opting out of the settlement?
It's not really "high" pressure, but it's enough (~20 psi) that RTV on the outside is almost 100% likely to NOT work no matter how clean you get it before applying it.When they leak is it a high pressure leak or would possibly some hi temp silicone seal stop it?
Thanks, not to belabor the point what about JB Weld? I would probably try that if I could reach it. I hope it is a while as only 5k mi on car now and I drive 2200mi/yr. !! 🙂Maybe someone will try it. I would change my own coolant and wouldn't be able to use the warranty anyway.It's not really "high" pressure, but it's enough (~20 psi) that RTV on the outside is almost 100% likely to NOT work no matter how clean you get it before applying it.
I'd be doubtful about that also. But if you could find the exact location of the leak and clean it well, it might work for a while. The 2 issues with anything semi-rigid on the outside sealing a leak in a plastic part are 1) to get good adhesion, and 2) to not have the different thermal-expansion coefficients make it come loose.Thanks, not to belabor the point what about JB Weld? I would probably try that if I could reach it. I hope it is a while as only 5k mi on car now and I drive 2200mi/yr. !! 🙂Maybe someone will try it. I would change my own coolant and wouldn't be able to use the warranty anyway.
Thanks. So it seems we should decide based on our currenty warranty right? My 2018 has a 6 yr basic and powertrain warranty, so that would take me through 2024. If I had a water pump failure in 2025, then I would be responsible for the cost since I'm out of warranty and not in the proposed settlement correct?VW would continue to be liable for all water pump replacements and related engine damage to the end of the 6 year warranty period rather than just the first time it happens. If it is like my Passat it took the dealer 3 tries to get a water pump in that didn't leak. Under this settlement I would have had to pay for the last 2 replacements. The risk is that I might have to foot the bill myself if the water pump the fails the first time after the 6 year warranty .
Since it's most likely the housing, to access it, you pretty much need to remove the intake manifold. You can try to flat rate it by just doing the throttle body but that is way too much of a risk to get something wrong. If you want some real fun, try to replace the belt for it as it runs off the back of the balance shaft and it has a LH threaded bolt that's a joy to get off. At least it's not like a Ford 3.5l V6 that's in things like an Explorer. It's internal and runs off the timing chain. Pays 15 hours to replace.I'd be doubtful about that also. But if you could find the exact location of the leak and clean it well, it might work for a while. The 2 issues with anything semi-rigid on the outside sealing a leak in a plastic part are 1) to get good adhesion, and 2) to not have the different thermal-expansion coefficients make it come loose.
