1 - 14 of 14 Posts
ok someone posted that knew what weather stripping to use to install pop out rear windows in a golf. i tried search and couldn't find it. can someone pipe up with a part # or where to source these?
Re: weather stripping for pop-out windows (kevinmacd)
actually i was thinking about replacing the rears with lexan or something similar. less worries on broken windows and you can brew up some pop-outs!
Quote, originally posted by kevinmacd »
i got a set of pop outs i coudl sell you
complete 1000 shipped!
Damn Cowboy, put down the
They're not that rare.
2006 P+ A4 3.2 Avant, 2011 C'Dale Bad Boy, 2014 C'Dale Carbon Synapse, 2019 P+ Q5
hahahahahahahahaha
Pennies??? SOLD!!!
I used a stripping from an auto interior supply house. They attach a foam seal to the side of a 1/4" 'cup' kinda like on rabbit door stripping. The foam was a 1/2 inch (theres also a 1/4" and a 1") and I think I ended up using 20ft. Ill get some pics...As soon as I get off my but and get out to the car again (hey Im lazy and I took it appart Hahaa)
Re: weather stripping for pop-out windows (Clav)
this is something i was contemplating too. why don't more people do this?
Quote, originally posted by Clav »
Re: weather stripping for pop-out windows (mdwstA4)
I think the reason people are not doing it is that the glass/lexan needs to be curved. I just sold my set and was thinking about tring something like that too but then couldn't figure out how to pull it off.
Discussion Starter · #10 ·
Re: weather stripping for pop-out windows (spdfrek)
Quote, originally posted by spdfrek »
well theres an answer worth posting
I din't realize they had a curve to em. ahh well good idea anyway
i bet if you took your stock rear windows to a sunroof shop they could drill holes in them and track down some appropriate latches, because they drill glass for non oem sunroofs all the time, and use very similar latches. if you found a competant shop, i bet itd be a good place to start
Re: weather stripping for pop-out windows (ValveCoverGasket)
I bet if you used that same sunroof shop they could "magically" stretch the stock windows to make them bigger like the Happich ones.
Re: weather stripping for pop-out windows (Harold)
I would like to know about seals as well, bump.
Premium Member
1 - 14 of 14 Posts
