So I have a 84 GTI I have fitted a 32/36 carb with. I was able to get it pretty well tuned but I have a couple issues. The stock jets are making the car run a tad bit too rich. I have a air fuel mixture gauge that is helping me to conclude this. Also when you go full throttle it has a bit of a hesitation before it clears out. I have ordered leaner jets. This is not the real problem I am having however.
I have driven it about 400 miles with the carb. My real issue is that the car will run great but then I can hear the fuel pump knocking then shortly after this the car will die (starved for fuel). I have found out that if I go and relieve the pressure at the fuel cap this will fix the problem and the car will start right up. I made sure when I converted this over that I chose a good fuel pump. It is a FuelFlow 015 pump made in New Zealand.
Any insight on why when the tank builds too much pressure the pump fails to work properly?
