Long time listener, first time carber. My questions are at the end, but first some background.
I am very nearly done installing the K402 Weber kit onto my 1980 Dasher. It's been interesting. First time messing with carbs, swapping the car over from CIS Basic because I'm feeling experimental and I got tired of CIS. I don't have much experience to draw on, but I am already waist deep in this, and there's no turning back. I'm certain there are things I need to learn to set this up correctly which would have helped me appreciate CIS more.
My questions:
Thank you in advance for any help given.
Think I might be able to get this going this weekend.
- A review of the K402 kit: Good stuff. Even the 2-3 page explanation of some of the initial setup and tuning of the 32/36 is chock full of information, and the people at Redline are truly quite helpful over the phone, including specifics about the 8v 1.8.
- I'm using the Carter 4070 on the recommendation of this forum, mounted to the side of the spare tire well. Pretty loud but that's easy to fix if I ever care enough.
- Mr. Gasket 1-5psi regulator, definitely cheaped out on this one, but it was recommended to me by some parts guys who have also needed to run pressures lower than 4psi, which is where a lot of standard adjustable FPRs bottom out.
- I'm using the original CIS hardlines with hoses clamped on the flares at either end. I'm not a huge fan of this solution, but I was struggling to find a proper way to connect hose to the original fittings. May wind up replacing completely with a hardy hose meant to run underneath the car.
- Using the harness end for the WUR for the electric choke, because it's my understanding that it sees 12v all the time.
- Replaced the throttle cable with a longer aftermarket one for more flexibility. The location and arrangement of the linkage on the carb prevented me from using the throttle cable bracket on the valve cover. I made my own with a fat piece of angle iron. Another thing I expect to change. It doesn't flex much but it damn sure is ugly.
My questions:
- The Redline manifold has two large ports on the outside runners. They have a bit of a barb, but the casting is rough and frankly doesn't seem right for a hose attachment. There is a seperate threaded hole to pick up manifold vacuum for the brake booster. Any reason not to plug them? I can't think of anything else that can use that much vacuum.
- It seems like I'd want to use ported vacuum on the vacuum advance distributor. At least, that seems like the best way to apply advance at low throttle. Can anyone help me understand why I should/should not use manifold vacuum?
- The Dasher has a charcoal filter canister mounted in the engine bay. It has the lines that run back to the gravity valve and filler vent. It also has a large hose on top which if I'm not mistaken, should go to the air cleaner housing (there is a port)
