I went to test fit a set of 45 DCOE13s on a two piece TWM long manifold, and I ran into a
problem with the ends of the throttle shafts interfering with each other, preventing the two
carbs from mounting.
It's almost a centimeter of interference, but before I go crazy and trim the shaft ends, is
there something about this that I'm missing?
Lousy pic, but you can kinda see the shaft ends in between the two carbs interfering, preventing
the carb on the right from mounting on the manifold:
