recently, the driver's side outer cv joint on my 81 rabbit started making noise. i usually just buy reman shafts, so i picked one up from a reputable local shop. i installed it tonight, but something is really wrong with it. the install itself went smooth, but when i put the car in neutral to turn the shaft for easy access to all of the bolts, it wouldn't turn at all. it's like it's all bound up.
when i turned the steering knuckle with the tie rod end popped out, instead of the outer joint just moving back and forth like it normally would, it turned the whole shaft forward or backward depending on which way i was turning the knuckle.
i know something isn't quite right, but what could it be? the shafts for westy rabbits are the same from 81 to 84, right? could i have gotten a funny length? is there some cross-pollenation from 80 to 81? is it just a junk axle?
any help is greatly appreciated. i gots to get this thing back on the road.
lucas.
lucas.
