1 - 12 of 12 Posts
Lately I've been noticing a strange sound right after I start the car in the morning. It's a high-pitched whistling/squealing noise. It stays on for about 30 seconds and stops immediately when the idle drops down to normal. I'm hoping this is just the starter or something. Any thoughts?
Thanks.
-Imp
Discussion Starter · #2 ·
Re: weird sound right after starting (improvius)
anyone?
Discussion Starter · #4 ·
Re: weird sound right after starting (Killer T)
Hmm - thanks. Next time I'll see if it goes away when I put in the clutch.
-Imp
Ok, problem was back this morning. I tested it, and clutch action has no effect whatsoever on the noise.
to recap:
-high-pitched whine/whistle/scraping noise
-happens on cold starts (even in warm weather)
-lasts EXACTLY until idle drops to normal, after about 30 seconds
-revving engine manually AFTER the noise has stopped will NOT recreate the noise.
-Imp
I would imagine secondary air injection. Keeps the emissions down at cold start.
Eric
I have the same problem, my noise comes from the valve cover (timing belt side). Not sure what could be causing this but it sure does not sound too good.
On top of everything my car is a year old with 11k on the odometer.
Re: weird sound right after starting (OhioUGTI)
Quote, originally posted by OhioUGTI »
Eric
I do not think it's that, simply because it sounds (in my case) like metal to metal grind.
Discussion Starter · #9 ·
Re: weird sound right after starting (ABTMuDa)
It's difficult for me to tell if it's a metal/metal or just an air pressure sound.
-Imp
secondary air pump. I posted when mine got noisy and was like wtf??
one reply was from a vw tech who said they replace a lot of em... had stlrship replace under warranty, problem solved.
my air pump got prgressively noiser, loud-whiny-buzzy-helicoptory...
good luck
Quote, originally posted by improvius »
-Imp
maybe you have a bad serp belt idler or pulley and once the rpms of cold start warms it up it stops. Just a shot in the dark i have seen things like this in the past. http://****************.com/smile/emthup.gif
Discussion Starter · #12 ·
Re: weird sound right after starting (DubGray1.8T)
Well, since it happens for EXACTLY the same duration as the high idle, it seems like the secondary air pump might be the best bet. I doubt it's something warming up, simply because the duration is always the same. So, any ideas how I could test the air pump?
EDIT: I have a vag-com, and as of last night it wasn't throwing any codes.
Thanks.
-Imp
Modified by improvius at 9:25 AM 5-20-2004
1 - 12 of 12 Posts
