Ok so my radiator fans dont kick on any time after I shut off my car... even after driving it awhile to get the temp up. Is there any way to test the fan control module? Are the fans and the secondary water pump supposed to run when the key is turned to accessory? The fans dont but the water pump does... AND are the fans supposed to run when you flip the climate control switch to defrost? :what:
