Quote, originally posted by abetterkyle » |
we turn up the boost and it acts like its missing like crazy! |
Quote, originally posted by ValveCoverGasket » |
could be too much water putting out the spark. can you try running without the WI on? do you have an intercooler? |
Quote, originally posted by Jefnes3 » |
more power is NOT made by adding water/meth inj. More boost the only way to get there. Water/meth just allows you run more boost than without, and add ignition timing. (you can do this yourself) Unless your into the mid 20's psi boost you shouldn't need meth. inj. Power numbers are good for ~15psi boost. -Jeff |
Quote, originally posted by .therealvrt » |
correct me if i'm wrong but almost 13 to 1 AFR is not good for a boosted setup |
Quote, originally posted by Salsa GTI » |
Ok your wrong....... Anything under 13 is good....too much fuel is for covering up other tuning problems like to much timing or compression.....anywhere between 12-12.9 is all good..hell even 13 ![]() |
i dont really need to water meth? |
Quote, originally posted by billy mitchell » |
please dont continue posting your misleading beliefs fact. |
