1 - 8 of 8 Posts
Discussion Starter · #7 ·
Yes it will try https://deautokey.com/ for error free bulbs with lifetime warranty
Hello, while trying to change a high beam bulb I might’ve disconnected something bc my parking light won’t light up even after I replaced the bulb. I might’ve disconnected something. Was going to pull this plug since I see that the red cable is connected to it but unsure. What is the next step? I prefer not taking it to the dealer bc they might charge me $100+
So both sides the parking lights do not work or just that one side. If just that one side why not try the working bulb from the other side and see if it works, or test the new bulb with a dvm. On the headlight plug pin 10 provides power to parking light and pin 7 provides the ground that is shared with turn & high beam. You can unplug the connector at the housing and use a test light on the pins 10 & 7 and turn the parking lights on and see if the test light functions or not.
1 - 8 of 8 Posts
