yea i have a question about what amp i should run with this subwoofer?
i want to have an amp that is safe with the subwoofer. by this i do not want to have the sub running to much over the RMS, i think it is 700 so i would like to run around 800-900watts
i do not understand the dual 2ohms and all that weird stuff so i would like to run only 1 amp. so just hook me up with what amp i should run?
here is the info for the sub:
MB Quart RWE-352
Peak Power Handling: 1400 Watts
RMS Power Handling: 700 Watts
Frequency Response: 16 300
Subwoofer Size: 15"
Impedance: dual 2 ohms
Dual Voice Coils
Basket: Cast alloy basket
Recommended Box 1 (Vb): 1.50 cu. ft. sealed
Sensitivity: 1,6dB
Cone Material: Treated paper diaphragm / Poly parabolic dustcap
Former: Kapton
Terminals: Gold binding posts
here are some amps that i thought i might use
http://www.woofersetc.com/inde...=4257
http://www.woofersetc.com/inde...=2499
http://www.woofersetc.com/inde...D=517
ALSO IF I BOUGHT THIS AMP
would i be able to turn down the wattage provided to the amp when i run it at 4ohms 500rms?
MB Quart RWE-352
Subwoofer Size: 15"
Dual Voice Coils
Sensitivity: 1,6dB
Former: Kapton
