What are diffusers exactly?
624 Views 10 Replies 8 Participants Last post by  16v
I've heard alot of talk on rear diffusers and how they help a cars aerodynamics, but now I just read a thread that talked about front diffusers. What are they, how do they work and how you you make/build/buy/aquire one?
1 - 11 of 11 Posts
Re: What are diffusers exactly? (Swollen)
front diffuser:
rear diffuser:
there's not much use for a diffuser setup on a street car since you're not hitting the speeds required for them to work. They act as an underbody wing to create a suction to the pavement - thus, increasing traction/control
[Modified by 16v, 1:58 PM 2-11-2002]
See less See more
2
of course they are for creating downforce, but HOW do they create downforce.
I believe it comes down to airflow speed. As the air is compressed under the car, low pressure is created..a diffuser directs and accelerates out of this low pressure area...
Re: What are diffusers exactly? (clickhappy)
see how its curved? its actually the top half of an airplane wing upside down. this is meant to counteract the top of the car's cuvature that creates low pressure (lift). By counteracting this lift, you create more traction. Also, they can smooth out the airflow and reduce turbulence. ( i think)
on the front, the air gets channelled around to the sides of the bumper, where little winglets then force the air up, pushing the car down, hence more traction. Also, the front air dam channels the air to pass under the chassis and thru the rear diffuser, where it creates more downforce.
[Modified by SauerKraut, 8:28 PM 2-11-2002]
See less See more
2
FYI~ these two images are of completely different race cars
Re: What are diffusers exactly? (16v)
nevermind.
[Modified by SauerKraut, 8:51 PM 2-11-2002]
Re: What are diffusers exactly? (SauerKraut)
The air coming off of the back doesn't really make that big of a differnce when you don't have anything else under the car as well. But if you were oh say driving a new ferrari at 200 mph, you could drive upside down because you have soo much downforce from the undertray of the car.
Re: What are diffusers exactly? (a2vwnick)
"A diffuser allows the air traveling underneath the car a place to expand and decelerate back to road speed as well as providing wake infill. As the air enters towards the front of the car it accelerates and reduces pressure. There is a second suction peak at the transition of the flat bottom and diffuser. The diffuser then eases this "high velocity" air back to normal velocity and also helps fill in the area behind the race car making the whole underbody a more efficient downforce producing device by reducing drag and increasing downforce.
Understand that a true flat bottomed car (one without a diffuser) will produce downforce in and of itself when run in rake. Essentially the entire flat bottom becomes one large diffuser. It too has two suction peaks, one upon entrance, the second at the trailing edge of the flat undertray. A diffuser acts to enhance this underside suction, it acts like a pump, encouraging better flow under the car.
One thing to note is that the rear wing interacts with the diffuser "driving" it. The proximity of the low pressure side of the rear wing encourages better flow through for the underbody. "
http://www.mulsannescorner.com/ http://****************.com/smile/emthup.gif
See less See more
2
Re: What are diffusers exactly? (Tuomas)
Looks like we've got an aero engineer on our hands.
See less See more
quote:[HR][/HR]
http://www.mulsannescorner.com/ http://****************.com/smile/emthup.gif[HR][/HR]​
I was going to say someone took that from Mike's site. You all should go over there and read up on his info. He's a smart cookie
See less See more
3
1 - 11 of 11 Posts
