1 - 13 of 13 Posts
my clutch is starting to slip real bad so i would like to replace the whole thing....
what are the options that i can go with... and how much would they cost..
i can install, i just need to know what to buy.
Re: what clutch to buy and how much.... tanks (ghostrider)
Just get an OEM clutch. sport clutches arent worth the price unless you plan on racing, or tons of HP. Ive heard about using an 8v clutch and a 16v pressure plate or some kind of whacked combo like that. my .02
Re: what clutch to buy and how much.... tanks (SeattleGLI)
so i was looking at this and the price is great.
http://www.parts4vws.com/catalog/product_detail.asp?PartNumber=027198141A
then you gotta get this when doin the clutch
http://www.parts4vws.com/catalog/product_detail.asp?PartNumber=8V198KIT
then i just need a new flywheel and i am set??? right on... so if thats the case cant i do this for under 250?
edit... jon you are my true love. sachs seems nice... what do you have?
[Modified by ghostrider, 12:40 AM 2-13-2002]
Discussion Starter · #7 ·
Re: what clutch to buy and how much.... tanks (SauerKraut)
quote:[HR][/HR]dude, forget this parts4vws crap, just find a local seller, and save on ordering hassles.[HR][/HR]​
so where's your closest cheapest recommendation foo
quote:[HR][/HR]edit... jon you are my true love. [HR][/HR]​
Aww. And just in time for Valentines Day, too.
I have a Sachs 210mm 8v clutch and stock 8v PP. Works fine for me, but then again I'm not at the 'strip every weekend. We'll see what happens when I do the motor swap...that is, if I ever stop buying more damn parts and actually DO the swap
[Modified by SeattleGLI, 2:06 AM 2-13-2002]
quote:[HR][/HR]...that is, if I ever stop buying more damn parts and actually DO the swap
[HR][/HR]​
*big grin*
shhh, dont listen to him, hes kinda messed up right now...
The price of a 16V PP is less than $10 of that of a stock 8v PP
go for the 16v
also I have been told that the stock sachs turbo diesel disc is a beefier unit. It fits on the 8v tranny too. I got one, i'm gunna give it a try.
tracy @ TRM can hook you up. Actually he was telling be about he stopped stocking 8V PPs, he sells 16v PPs with all his discs
BTW, unless you melt the thing by driving on the slipping clutch too much, you probably don't need a new flywheel. Try to find a local place that'll get you one for under $100, then only get it once the car is apart and you see that you need one. Otherwise, save your money. If you're planning to get a LW flywheel of course then do whatever.
And do people actually see clutches priced similar to Potterman's locally? wow. I can't find a clutch superset for under $150 local.
1 - 13 of 13 Posts
