1 - 20 of 32 Posts
Banned
so my car was rattling from what sounded to be the right front. no biggie, jacked it up, looked around. i was tapping the brake rotor to see where the noise was coming from, and i pinpointed it to what the bentley calls the "splash shield". i wiggled it around to reshape it a bit and make it stop rattling. i would make a guess to say i didn't move it more than 1/16". put the wheel back on, etc. etc. roll back off the lift and SCREEEEEEEECH!!!!!!! :shock: what did i do wrong? is the shield rubbing against the rotor? i can't tell what it's rubbing against by looking at it. i only drove it 10 feet into my garage, i'm gonna check it out later. any ideas?
Banned
i had a similair problem with my mk2 i just bent the thing back to look like the other side, also make sure it isnt scraping your wheel because i bent it way out of the way first and it was scraping the wheel, its i pain in the buss to bend it tho
Banned
Re: what did i do?!?!? (Pfeil)
well i'm going to work on it right now, bend it around with the car in neutral so i can spin the wheel to listen for grinding. and other suggestions?
Quote, originally posted by Pfeil »
shock sway bar? looks like a tie rod to me bud.....unless they renamed it..
Re: what did i do?!?!? (tunedjetta)
Quote, originally posted by tunedjetta »
Hehehe... Indeed it is the tie rod, the swaybar is pictured in Diagram #3
Oh, and the answer to your question is 44.
Modified by LostBoyScout at 2:51 PM 7-1-2003
Banned
You probably bowed it in when you bent it and now it is scraping further down out of sight.
P.S. That is a tie rod, not a sway bar.
Banned
Discussion Starter · #10 ·
Re: what did i do?!?!? (late_apex)
oops. i knew that. really. i did.
well i solutioned the problem. basically, when i was wiggling the shield, the screw that holds it in came out a lil bit and was rubbing the rotor (not on the braking surface, the hub area). an open ended wrench did the trick. i put some double stick 3m outdoor tape stuff in between the shield and some metal part it was rattling against. problem solved!
i'd like to thank my sister for holding the flashlight, and bentley publishers for their helpful diagrams.
Banned
Discussion Starter · #14 ·
Re: what did i do?!?!? (Jettaboy_1)
Quote, originally posted by Jettaboy_1 »
Evan you are a trip man LOL
thanks joe. glad i could entertain everyone.
stupid noob
its the splash sheild rubbing on your abs sensor
when you and rich jacked the suspention back into place with the jack under the rotor you bent it (I looked in horror as you did this)
Re: what did i do?!?!? (VReihenmotor6)
Quote, originally posted by VReihenmotor6 »
Thanks for your help then
Glad you got it figured out Evan.
Banned
Discussion Starter · #17 ·
Re: what did i do?!?!? (Uncalm)
yeah thanks for mentioning it to us john...
no abs light so it's all good.
well, I had no idea you did any damage
but personaly I like to jack from the control arm to raise the suspention
thats all
1 - 20 of 32 Posts
