1 - 4 of 4 Posts
Hi having some headaches trying to take of rear discs on my car.
I have take all the stuff off e brake line the caliper the only thing left on is the caliper brace and the the rotor itself.
The thingamajig is held on by 2 hex screw
i got the top one off but i have no room to get to the bottom one with a rachet set.
I got a set of allen keys but i bent the poop out of them tryin to get the stupid screw off.
any help would be much appreciated.
P.S. i said piss on it for now it is sitting in the garge all dismantled. Not about to put it back till i get everything off
Re: What did u guys use to take off rear discs (more inside)? (Cupavi)
the bottom screw is a pain. I had to use the ratchet set at an angle and use a mallet to make sure I dont strip the screw.. Done that a few times - helps to get new screws every time just in case - they are not too expensive (I haven't done that though)...
Good luck..
Re: What did u guys use to take off rear discs (WannaCorrado)
Wanna has the trick. You gotta throw some penatrating oil (nice) on there, and then hit the screw with a punch and hammer. Make a note to not ruin the head...or it will surely never come off without a drill. But, just hit that thing many, many times, very, very hard. Then just gently torque it off. Then hit it some more. Sometimes you can tighten easier then loosening...so try that, and then back her off till you get it. Best of luck!
1 - 4 of 4 Posts
