@ratfalia nice work! Did you remove the chrome window trim and if so, did you find a guide on how to do it?Obligatory first post.
2019 se Dark Moss Green Metallic Tigy w/ 30k miles that I bought for the wife. Jan 5th, 2022
This weekend:
Fully detailed it washed polished and waxed.
Blacked out chrome (Plasti dip) ok results may take it to get it wrapped. (didn't to grill due to having the ali express covers on the way)
blacked out rear emblem and SE badge
Removed rear tint that some one put on top of the already tinted windows (couldn't see at night)
Changed rear cargo light to led
Added dynamic center caps
CERAKOTE trim pieces. Looks great will update on how long it lasts
Added arm rest console insert
Added vw emblem rubber cup holder inverts
Added Amazon rear hatch cover aftermarket. Not recommended. :/
Ordered parts on the way:
Ali express foglights
Led marker lights
Dash board console
Black out grill inserts
Blacked out emblems
Tuxmats
black aluminum Rear bummer protector
Vw logo door lights
Rear under seat ac vent covers
R-line door hinge covers
R-line steering wheel add on
Items I'm looking at adding:
Dynamic rear LED markers
Extra trunk lights Ali express. Wondering on wiring.
Looking into aftermarket rear tailgate lifts (auto)
Dash cams
Probably wheels but I kind of like these 17's they don't look bad
I would mind lowering it but it's the wife's car... So she will prob yell at me lol. But they look so good lowered lol.
Prob will do ceramic tint. To keep out the heat. Located in Cali and in "winter" right now lol like high 60's lol but can already feel the heat. I have the big glass sun roof and I can already feel the heat.
Debating on drilled and cross sloted rotors. Fronts seam to feel a bit warped and might as well upgrade. View attachment 149710
View attachment 149712 View attachment 149710
Windows Down works by default, not windows up. Pressing the door button and holding it closes the windows. The roll up with keyfob never worked for me.Pretty sure 7 worked in my vehicle with no coding. (It also does the Pano Roof)
Curious about 3.
Would like code for 6.
Gauge sweep does not work with MIB3 vehicles (I know).
Let me know how you come out with the To Do list...please...
Bob.
Correct, but you can enable the pano to open as well but i don't personally care for the pano to openHrmmm.
You're right.
Normal scenario is hold the sensor on the door handle to close all windows and Pano.
Sorry. I misread.
I think a long press and hold (of the OPEN button) for mine will open all windows (not the Pano)
Bob.
I don’t believe it’s possible to change #1 in your To Do list. If you do happen to figure out a way to do that, please share how though many others have not been able to do that.Busted out the new OBDELEVEN. Made some changes on 2022 Tiguan SEL R-Line:
1. Lock vehicle from key-fob with ignition and engine running.
2. Display R Logo in Digital Cluster.
3. Change Digital Cluster Gauge Appearance w/ Narrow Font Lettering/Numbers
4. Lap Timer
5. Pulsing Start Button
6. Removed all Blocked screens for input into infotainment center while moving. Menus, Media, Navigation, etc.
7. Key-fob closes windows with long press
8. Disabled Seat Belt Warning
9. Disabled Ignition On Warning
(To make all of these changes, the Hood has to be open. Weird, but it worked.)
Attempted:
1. Remove Reverse Camera, "Look! Safe to move?" - car freaked out, all ACC systems error.
2. Gauge Needle Sweep - even though enabled, no sweep.
To Do:
1. Increase the amount of time before the vehicle alerts to steering input from driver.
2. Adjust Lane Assist to favor middle of road.
I don't use the sunroof much to be honest, I'm a vampire, the darker the better lol If I figure out the time before driver input is required I will certainly post it up.I don’t believe it’s possible to change #1 in your To Do list. If you do happen to figure out a way to do that, please share how though many others have not been able to do that.
One other you may want to consider is to keep the sunroof closing when you turn the car off. By default, if you turn off the car while it’s closing (in motion) it stops where it is.
Cheers…
DoC
Pretty sure that timer is hard coded for obvious reasons. That said, there is a way to defeat (cheat) the system and keep that timer from even starting.I don't use the sunroof much to be honest, I'm a vampire, the darker the better lol If I figure out the time before driver input is required I will certainly post it up.
No I just Plasti dipped them. It's like a spray on (removal) vinal spray. It came out ok but may end up getting it wrapped instead.@ratfalia nice work! Did you remove the chrome window trim and if so, did you find a guide on how to do it?
Disable ‘Auto-Unlock’ when putting in Park , Setting is under:Can you please share which adaptions you did to make 6;7;8;9 working?
Thanks!
@ratfalia sorry, I didn't phrase my question so well. Meant to ask if you found instructions/tips on how to remove the chrome window trim before plasti dipping them. For wrapping, is that essentially doing it yourself with a roll of blackout vinyl or something more tailored?No I just Plasti dipped them. It's like a spray on (removal) vinal spray. It came out ok but may end up getting it wrapped instead.
MUST HAVE HOOD OPEN FOR THE 22 TIGUAN!!!!@Burkett.ACB , how did you get the speed limit on the dash?
Also, I had tried the Select Depiction thing a few months ago and it didn't work.
But, I didn't have the hood open, will try again, thanks!
Bob.
My bad, just realized you have the 21', I'm not sure if you can enable it for your year depending on the equipment you have...Pretty sure the 21 has the same digital dash as the 22's (mine looks just like yours with WHITE LED's going up for GAS and Water TEMP).
I know I don't have the selection for the SPEED LIMIT in my Assist area (but I can look again).
I'm not real crazy about the VW nav system. At least for me, I get very few street names on my maps.
In fact when I was at my dealer, which is located just off of I-70 and I-75 (major crossroads for the US) it didn't even display NAMES/NUMBERS....dumb.
I use WAZE, and while you can't move it to the dash, it does show turn info in the dash.
Bob.
