Disable ‘Auto-Unlock’ when putting in Park
, Setting is under:
Body Control
Module 09 (Central Electronics),
you have to adjust the adaption channel "(25)-Access control-Autounlock NAR" from "Active" to "Not Active".
(I personally found by going to Coding instead of Adaption, and scrolling down to ZV Komfort, selecting ZV Komfort listed Autounlock NAR which I set to Not Active was the easiest way to locate this.)
Disable ‘Ignition On’ Alarm
-'This disabled the ignition on alarm which is activated when the drivers door is opened.'
Module 17
Adaptation
Search ‘Ignition’
Select “Ignition Active Message, Actuator”
- Set to ‘No Display’
Allow enter address/text while driving including access to all Vehicle menus which were previously blocked while driving.
1. Control Unit 5F
2. Security Access 20103
3. Adaptations
4. Search “Locked”, change all values from Blocked to Non_Blocked
(These remaining last steps 5. - 7. weren't necessary, up to you...)
5. Long Coding
6. Go to Byte 23
7. Uncheck all items (value for Byte 23 should be 00)
Seat Belt Warning Deactivation - '
Disables the audible seat belt warning.'
Select Control unit 17 (Dashboard)
Adaptation
Select : Disable channel belt warning
Value:Yes
Control unit long coding
Byte 0
Bit 2-4 Deactivate
Open/close windows with keyfob
Windows open when holding down the unlock button on the key fob. - 'Also close when holding lock button.'
-Select Control Unit 09 (Central Electronics)
-Security Access 31347
-Select Adaptations
-ZV Komfort
-Set Funk Komfort Schliessen: Not Active -> Active (**This is the only setting you should have to change, but in case your key-fob isn't programmed to open your windows I've included those below.)
-Set Funk Komfort Oefnnen: Not Active -> Active
-Set Comfort Opening: Not Active -> Active
(9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
Change to Active
Windows operate after turning off ignition and opening door
Lets you still operate windows after turning off ignition and opening door
-Select Adaptations
-Select ZV Komfort
-Set Freigabenachlauf FH bei Tueroeffnen abbrechen: Active -> Not Active
Lap Timer Activation
Enable the Lap Timer in the cluster.
Control unit Long Coding
Byte 1
Bit 3 Activate
Lock Vehicle With Remote While Running
09 - Central Electronics
Security Code 31347
Adaptation
Set (1) Access control - Funk bei Klemm 15 ein to Active
Change Digital Dash Themes - 'Change the gauges theme to different styes'
-Select Control Unit 17
-Select Adaptations
-Set Display depiction : Choose version (changes on dash in real time)
Add R Logo to Digital Dash
-Select Adaptations
-Search R Logo : Once Selected… Choose version (changes on dash in real time)
Known Security Codes!
Module access codes:
Module (01): 27971
Module (03): 40168
Module (09): 31347
Module (10): 71679
Module (13): 14117
Module (17): 25327 or 20103
Module (19): 20103
Module (44): 19249
Module (5F): 20103
Module (A5): 20103
