The racks are worth it. I put the Audi All-Road rubber inserts in mine to give it a slightly different look that literally no one will ever notice lolNice I'm seeing everyone with racks now
What low pass filter did you use to tap into the stock head unit?Hooked up JB4 and put in new plugs/coil packs today and got the rest of my stereo installed on Thurs.
View attachment 183612 View attachment 183613
View attachment 183615 View attachment 183616
Used the Audio Control lc7i, you can see it in the first pic with the amps.What low pass filter did you use to tap into the stock head unit?
Looks good!
Sent from my Pixel 4a using Tapatalk
What's the baby filter?Installed an ECS Big Bore Inlet Pipe and APR Open Intake. Was pretty straight forward although i would warn anyone installing the Big Bore Inlet, that the stock intake pipe would absolutely not fit over the new inlet. I had to use a heat gun and warm up the end of the stock plastic pipe to wear it would expand/give just enough to slip over the new inlet. My car is a 2022, so i'm not sure if the stock intake pipe is a slightly smaller diameter than previous years but it was definitely not going to go over the new ECS Inlet.
Silly question but did you buy the MK7 option or the MQB?Bought this exact memory plug for start-stop. Install was a breeze. Did it in 2 minutes. Working perfectly as of now. The start-stop stays in OFF position when I turn the car back on. Highly recommend this.
I got MQB Jetta, they might be the same they just don't know how to describe themSilly question but did you buy the MK7 option or the MQB?
Nice 👍 I discovered a new hyperdip that would also work. I might remove the front red lineJust got mine so haven’t done much yet. Blacked out my emblems, I love the contrast with the black/white.
I got the MQB option since that was the only one mentioned Jetta. And it works really good too!Silly question but did you buy the MK7 option or the MQB?
Probably hard to tell since you did the JB4 at the same time but do the coil packs make a difference?Hooked up JB4 and put in new plugs/coil packs today and got the rest of my stereo installed on Thurs.
Wish I had a garage, it won't look this good again for a whileGetting a full interior/exterior detail today. Holding off another year for the full paint correction and ceramic coating.
Just got my exterior done too lolWish I had a garage, it won't look this good again for a while
