Wow, nice bay. I want my TSI to look like that when it grows up!20 g/s Primary injectors and 1200 cc Secondary injectors for my FSI View attachment 181610
I spy a Eurojet valve cover and catch can. I love my Eurojet R32 style exhaust.20 g/s Primary injectors and 1200 cc Secondary injectors for my FSI View attachment 181610
Wheel specs? Any spacers needed?Also got the 18z installed finally and bought 310mm rear calipers for $150 so will install those when rotors/pads arrive. Also ordered the evo header which should be here in a couple weeks. Excited for that piece.![]()
Picked up this car a few months ago and finally cleaned behind the fender liners... No wonder it was starting to rust!
Hawt. So, how much improvement would you say the 6-spd is? Much less rpm drop on the 1-2 and 2-3 shifts?Got a couple decent pics today. 18z kit looks great. 6 speed swap is officially done.
From reading the ratio charts, I’d say definitely.Hawt. So, how much improvement would you say the 6-spd is? Much less rpm drop on the 1-2 and 2-3 shifts?
Gear ratios are a lot better so acceleration is a better. Also the transmission is a lot stronger.Hawt. So, how much improvement would you say the 6-spd is? Much less rpm drop on the 1-2 and 2-3 shifts?
Good to know. I plan on swapping out the 09g for an 02q eventually.Gear ratios are a lot better so acceleration is a better. Also the transmission is a lot stronger.
Do you have a thread where you documented everything during the process? I remember reading about this swap not being a direct fit, but that was a while ago now. It's nice to see people having success even now, and I'd love to have a six speed in my 2.5 down the road.Gear ratios are a lot better so acceleration is a better. Also the transmission is a lot stronger.
I didn’t document but that’s because the info is on the fb groups. It does bolt up. You just need to shave 1/8” off the top of bellhousing so it doesn’t touch our timing chain cover. Pics online showing how much to shave/grind (not much at all). Besides that it’s just GTI trans and axles, GTi/GLI fsi clutch kit and starter and shifter mount bracket. Also a short shifter. Just like doing a clutch job except you are replacing it with different parts. Clutch kit and starter must be from a gti/gli fsi. Have to use one bolt from the GTi bellhousing (left bottom). It’s better just to take the GTi bellhousing bolts aswell with the swap you buy to have everything. Very simple swap.Do you have a thread where you documented everything during the process? I remember reading about this swap not being a direct fit, but that was a while ago now. It's nice to see people having success even now, and I'd love to have a six speed in my 2.5 down the road.
Cheers!
Cheers!
That is a great write up. I’m gonna save that. Thank you![]()
07k 6 speed swap write up.docx
Parts list: FSI (05-08 GTI, GLI) clutch disk, pressure plate, flywheel, clutch release bearing, and hardware 02Q 2WD 6 speed transmission (05-14 GTI, GLI, 2.0T, etc) with vertical mount bracket (the thing the transmission mount bolts to) 02Q 2WD driver’s and passenger side axles with outer hub bo...docs.google.com
From here Laser Blue 2009 Jetta Sportwagen 2.5S Build
