Installed my frameless mirror.
Sent from my Samsung Smart Fridge
Depends is it worth it to you? It was to me. I got a nice Mk6 Golf R motor to replace mine. All and all its was close to $4k to do.found out my motor is blown.
is it worth putting a new block into it? or should i walk away?
ten days before this happened i put a new stage 2 clutch in it... (and no i wasn't beating on it... the oil pump failed)Depends is it worth it to you? It was to me. I got a nice Mk6 Golf R motor to replace mine. All and all its was close to $4k to do.
Sent from my SM-G990U using Tapatalk
I have VWR springs with Bilstein B8 sports. It’s so smooth. Almost stock ride. I went with mk6 sports. They are not as firm.Before and after pictures. H&R super sports with bilstein sport shocks VWR springs and shocks. Plus VWR subframe mount and Tyrolsport deadset. Shifts and rides so smooth!!![]()
You can use a motor from a dsg.so the guy who built my car told me that if the the clutch is too stiff it will cause the thurst bearing to fail which is what happened in my car... so i'm thinking that the clutch was not properly installed...
of course my shop is claiming no responsibility.
tangentially... can i use a motor from an automatic car in a manual car? or are there too many parts to swap over?
How many miles was on the pump?so the guy who built my car told me that if the the clutch is too stiff it will cause the thurst bearing to fail which is what happened in my car... so i'm thinking that the clutch was not properly installed...
177k on the clock.How many miles was on the pump?
For the thrust bearings do a search on the clutch pedal bypass/harness, this will allow you to start the engine without having to push pedal in and which can cause wear especially on cold a engine.
Any BPY short or long block will work just swap over your ancillaries/sensor from your old engine.
You are just swapping in a short/long block/engine into the existing car so nothing needs to be done with the Ecu. Just swap over your ancillaries/sensor from your old engine over to the replacement.will my ecu with my stage 2 tune swap or will i have to get a new ecu and have it flashed?
so many variables... sigh
Oh please, give out the deets on your setup!Installed my frameless mirror.![]()
That’s terrible. I don’t know him personally but have complimented him on posts as I do any other fellow dubber still on vortex. My condolences to his family. Thank you for sharing.Sad news. Saw him around here a bunch, so thought I’d share. He will be missed.
https://www.reddit.com/r/GolfGTI/comments/upvbx9
Those plug are nice. One shade cooler than the platinums. Should be able to pull more timing.Changed the spark plugs with ZFR6T-11G and fixed the intake box at the grill. The two tabs on the sides were long broken off. Just drilled two holes on top and relocated the speed clips to those holes. Then, used two spare screws I had.
It certainly started quicker. Can't tell any driving difference with the old butt dyno.Those plug are nice. One shade cooler than the platinums. Should be able to pull more timing.
Snapped a shot after I pulled it out of the garage --Installed the right front strut which was the last of a full set of Bilstein B4s. For some reason I had the worst time inserting the new front struts into the steering knuckles. Super tight fit.
Very happy with the B4s. Noticeably firmer than stock but still comfortable. They pair well with the 18" Michelin PS4ses that I'm running. Car is very dialed in now.![]()
Stock springs? Did your car have sport suspension?Installed the right front strut which was the last of a full set of Bilstein B4s. For some reason I had the worst time inserting the new front struts into the steering knuckles. Super tight fit.
