1 - 4 of 4 Posts
thinking of putting one in my 2.0 16vT, it's running the stock ecu of course, would it be worth it or u think i can get away with running 10-15 lbs with a mid 9:1 compression with enough fuel and a FMIC?
thanks, Paul C
Re: what do u guys think of the msd boost retard? (killa)
The only problem I see is that you wouldn't have any ignition advance without your knock sensor system hooked up. Maybe you could use a euro distiributor which I believe has mechanical and vaccum advance but it also has points. Then convert it to electronic and run MSD.
1 - 4 of 4 Posts
