1 - 11 of 11 Posts
Re: What does haveing a broken swaybar link affect??? (scottb15)
Predictable handling... and the posibility of having it wear / vibrate.
It's drivable with no problem, but it'll affect your race days to somewhat of a degree.
- Erik
FIX IT NOW! If its free to move around when you corner the bar can/will flex up into the cv boot ,cutting it and making more work for ya.
2022 Odyssey Touring, 2018 VW Atlas SEL R-Line, 2008 VW Jetta 2.5
Re: What does haveing a broken swaybar link affect??? (mikebobelak)
A buddy of mine bought a 92 Corrado SLC and found out it was somehow missing one of the sway bar links. Also, his CV boot on that side was ripped wide open. He replaced the boot, thinking he could do the sway bar link later. After going for a drive around the block, he found out his new CV boot was completely destroyed from the end of the actual sway bar.
Quote, originally posted by mikebobelak »
this is where im at.
one side broke off, and rubbed the cvboot and i have a nice mess all over there,
and the other side i screwed up and forgot to tighten when i put in the poly a-arm bushings, and that fell off and started to rub the cv...luckily didnt wear through!
i broke both mine.. so i made some replacements from spherical end links.. no more rubber, no more play
i posted pictures on vortex months ago, but no one seemed to give a ****
Re: What does haveing a broken swaybar link affect??? (PhOO)
Quote, originally posted by PhOO »
Can you link to the thread please? I searched and couldn't find it.
Are they adjustable in length, I need endlinks that are shorter than the stock ones, my autotech sway bar touches my brospeed header and I can't adjustable endlinks anywhere.
Re: What does haveing a broken swaybar link affect??? (HisMajesty)
just ditch the front sway bar, you dont need it. pretty easy to remove.
then decide if you want to fix it.
1 - 11 of 11 Posts
