1 - 4 of 4 Posts
im going to be doing dsr 256's and giac 256 in the next month or so...and i'm thinkin of getting the cupholder gauge mounts and putting two gauges in. so far the given would be oil, but what should i get for the other gauge? i was thinking the volt meter but then again the car came stock with one. any help would be great, also...do the vdo vision series light up the same as the stock interrior lights?
Re: what gauges(2) to run with an NA vr6? (ToughGuy)
Well.. oil temp is a pretty good one, EGT (exh gas temp) is not really needed because it's better used as a guage of turbo temp, if you have an amplified stereo voltmeter's cool to have if not then its not, uhh you can do CHT (cylinder head temp), that would be pretty cool i spose!
1 - 4 of 4 Posts
