Re: what happens if i do this? (20VT*J4)
That is exactly what I thought, but for some reason the mechanic I took it to, said the opposite, and persuaded me to do it the other way, o2 sensor before, but If you think about it look at you stock dp/cat , that is the way it is setup?? Its weird?
Anyway did you have any probs with the second o2 sensor not fitting underneath the car? I did, it was too long and we had to bang up the heat shield some to make room for it. It is on right now, I had them change it yesterday. But when he banged up the heat shield, he hit the shift linkage and jammed it with the dent he put in the heat shield.
Now 2nd gear is how to go into. Before my tranny wouldnt even move at all. I was freakin out
Well its better but 2nd is tough. What should I do about this? The o2 sensor will not give way for the dent to come down anymore and allow that "knot" to come out so 2nd will shift easy. Any suggestions?
