1 - 20 of 28 Posts
Just wondering what is a slightly bigger turbo than a kO4 and what else would have to go into the build to make sure i didnt blow my engine, like will i need to upgrade rods and piston rings or oil and coolant lines and software etc. thanks
Re: What is a turbo slightly bigger than a KO4? (joevw007)
ko3
ko3s
ko4-001
ko4-020
gt25r
gt28r
t3 60trim
gt28rs
gt2871r
t3t4 50trim
gt3071r
t3t4 57trim
t3t4 60trim
gt3076r
gt3082r
T3/GT40
SC61
GT35r
Just a fast list
Re: What is a turbo slightly bigger than a KO4? (cincyTT)
Quote, originally posted by cincyTT »
ko3
ko3s
ko4-001
ko4-020
gt25r
gt28r
t3 60trim
gt28rs
gt2871r
t3t4 50trim
gt3071r
t3t4 57trim
t3t4 60trim
gt3076r
gt3082r
T3/GT40
SC61
GT35r
Just a fast list
ko420 looks like its for me, i wont have to replace rods/piston rings will i?
FV-QR
Quote, originally posted by joevw007 »
More than likely, those tiny turbos are good for a big TQ spike and no HP. Great for snapping rods.
You'd be safer on a GT35R at low boost than a high boost K04 any day.
Discussion Starter · #8 ·
Re: FV-QR (-Khaos-)
Quote, originally posted by -Khaos- »
ok thanks, this guy from CTS Turbo is trying to tell me i dont have to replace rods or piston rings with a gt28r and he thoroughly confused me.
FV-QR
You probably wouldn't... Unless you pushed it to the limit
The problem is, to make any power out of that tiny K04, you HAVE to push it, which just leads to big TQ spikes, which will kill the rods in no time flat.
I'd take the GT28/ over a K04 anyday.
Re: FV-QR (-Khaos-)
thanks spoolin
hehe... ko-420
ko3
ko3s
ko4-001
ko4-020
gt25r
gt28r
t3 60trim
gt28rs
gt2871r
t3t4 50trim
gt3071r
t3t4 57trim
t3t4 60trim
gt3076r
gt3082r
T3/GT40
SC61
GT35r
Just a fast list
you forgot my next turbo...well maybe my next turbo. gt4088r http://****************.com/smile/emthup.gif and of cource the almight gt3586r which is sexy
Modified by velocity196 at 10:09 PM 8-14-2009
Discussion Starter · #13 ·
Re: FV-QR (-Khaos-)
well what would not be pushing it to the limit/ how many lbs of boost would i be able to run on the gt28r and how much hp do you think i could make without blowing ****.
Premium Member
TTq, OBXT, Renegade
Damn fine list cincy http://****************.com/smile/emthup.gif
gt28rs = the disco potato, correct?
that's what I'm considering in the long run . . .
is the APR stage 3 kit a gt28r or a dancin tater?
Re: What is a turbo slightly bigger than a KO4? (ypsetihw)
Quote, originally posted by ypsetihw »
yep, gt28rs is the disco potato.
Stage 3 = gt28r
Stage 3+ = disco potato
Premium Member
TTq, OBXT, Renegade
Yep, disco potato = gt28rs = gt2860
FV-QR
Not pushing the K04 to the limit... I'd say 20 PSI, but then you'd be making 10-15WHP more than with the stock turbo... Probably around ~220WHP
On the GT28R (not RS), probably same PSI you'd be doing 60 WHP more... Or you could do about 280WHP or so.
From how i've read this..a k04 is a high psi, torque spiking, rod buster. If you can make more hp at lower boost on a gt28 why would anyone bother running a k04?? That really changes my views on ever running a k04. Sorry if this seems like a dumb question, I'm relatively new to this
Re: (CoopaCoopaCoopa)
Quote, originally posted by CoopaCoopaCoopa »
Small turbo turbine= fast spool= more torq, no big hp gains RATIO
bigger turbo turbine= slower spool= more hp gains less tork RATIO
BIG turbo turbine= slow spool= big hp to little torq RATIO... means more boost for more Ratio
BIG turbo + small turbo= wet dreams
1 - 20 of 28 Posts
