1 - 6 of 6 Posts
How's it going?
I'm in the process of building a 2.0 16v for my Scirocco. It is going to be all motor and so am looking for the best head gasket on the market to bump up the compression. Any ideas????
Re: What is the best 2.0 16v head gasket to use??? (VeeDubbin16v)
not as simple as that. be very careful about your valve clearance...
Re: What is the best 2.0 16v head gasket to use??? (Oreganoflow)
alright thanks for the info.....anyone got other ideas
Use the stock gasket. Bump up your compression by either shaving down your head (very slightly), or installing high comp pistons.
Re: What is the best 2.0 16v head gasket to use??? (Ted)
yeah the head is getting shaved very, very slightly. I was just seeing what my options were as far as getting more compression from the head gasket. I figured that you can lower the compression with a different head gasket so why not raise it http://****************.com/smile/emthup.gif
1 - 6 of 6 Posts
