1 - 13 of 13 Posts
Banned
Re: What is the best way to remove Night Shades from paint? (MK3)
Quote, originally posted by MK3 »
sandpaper thats how i did it
sarcasm or no?
I hope so.
Banned
Re: What is the best way to remove Night Shades from paint? (All_Texan)
Quote, originally posted by All_Texan »
sarcasm or no?
I hope so.
no thats how i did it it worked good, use rough on the top coat then use a fine grit after you get it all off it works, plus i did it on a car i didnt care about so if your car is nice you may not like the result
How much is on there? Is it just some overspray, or more? If it's just overspray, a clay bar run over the affected area may help. If more, you could try lacquer thinner if you're quick, but it sounds risky. You'll probably get more help over in the detailing forum.
Re: (winkosmosis)
Quote, originally posted by winkosmosis »
Overspray?? Aren't you supposed to tape?
It was REALLY BAD overspray.
Re: (PacerX)
if your car has a good layer of wax on it you should get it off easy with a claybar then klasse cleaner wax with some elbow grease
1 - 13 of 13 Posts
