Re: What is the easiest (cheapest) way to get some extra power (Calimus)
Advance your ignition timing to 8 BTDC (more if it doesn't ping). That should give you more grunt and better throttle response. You might want to get an adjustable cam sprocket to dial in more low-end. After this cheap stuff, you'll want a 2.0L short block (9A) from the 90-92 GLi, Passat, and 91-92 GTi 16v.
