1 - 9 of 9 Posts
Re: what is the headlight bulb size of a jetta. (ROCKRLR)
This is kind of off the subject, but do you guyz know if the yellow signal light next to the main headlight are interchangeable. This would be for a Jetta IV and I'm wondering if you could replace it with a blue city light.
Thanks for your help,,,
Peace
Re: what is the headlight bulb size of a jetta. (Jman5000)
First of all,,,
I think you just broke the record for fastest reply to a post ever!!! (The reply came within 90 seconds).
Second, I've spent hours on this board trying to figure this out and for that I thank you. Have a sweet Sunday!!
Cheers,,,
Ren
Slow down for a second. The silvervision bulb from Phillips will only work in the Golfs and not the Jettas as once again the Jetta is a two filament bulb but they are only made in single filament so far.
Re: what is the headlight bulb size of a jetta. (Silver Jetta 1.8T)
Just to further clarify:
The Silver Visions are PY21W. They will not fit the U.S. Spec Jetta lights. They do fit the e-code Jetta lights.
1 - 9 of 9 Posts
